phatchopper300
I just wanta ride
I hope I can explain my problem? Ok as I was riding last night about 45 min. into the ride I started hearing a spinning grinding sound
of which almost sounded like the primary chain hitting the front cover of the outer primary? It seemed to only do it when I would turn the throttle and as I would let off the throttle it would after a few sec. stop. It will not do it with the clutch pulled in it would stop instantly.???:bang:. Now to help with that being said I just about a week ago adjusted the clutch was having problem getting it in neutral. Bike has run great in the last week. Would the cold effect the fluid in the trans or primary. Low fluid in trans make that sound? I looked at primary chain it seems to be tight? Need help with diagnoses!!
Thanks
Mike
Mike
