Not exactly...That's what I understand our systems are. Ground based adapted from the airline industry. You basically short out a component to have it operate.
Either the person that told you is incorrect or the 2003 schematic that BD supplied is incorrect.i was told these switches work by grounding them when depressing them.if i remember right i believe they call them momentary switches.maybe wrong been wrong before:lol:
You were right about it being a momentary switch. It's only "on" while you're pressing it... :up:ooops,the 03 is like the harleys.toggle type switch?
Hahahhaha....... You fugger. Merry Christmas and a Happy New Year to you as well.Kool,
Then maybe you can just honk it with the motor "NOT" running.
Have a Merry Christmas and a Happy New Year!
dead
Damn Gabe that took some work, good job. :2thumbs:The horn power comes through "J2" #7 of the EHC.
You could take the wire out of the plug, P2 is the plug, wire position is #7 (green) and hook it to J4 #2 (Grey) @ EHC and eliminate the EHC all together.
Just keep in mind that your switch on the bar is now handling the current from the horn.
The electronic circuit breaker will still be protecting the circuit, but it may be questionable if the horn switch/button will handle the 3.5 amps.
But you can temporarily hook a relay up to handle the load.
I'll draw that circuit for you if you decide to use a relay. 3.5 amps is not much and the switch will probably handle the load.
Hope this helps...
PS. it looks like a bad EHC ? I would wire a separate circuit for the horn if needed
To bad the Kool man is just a funkin myth, I thought I saw him once at Leesburg hauling azz the other way?:loony:
you guys are just a damm jack of all trades aint cha,,,,, duct tape,, wire ties,,, tin foil... we do it but the book here.....:2thumbs: forgot the rubber bands....
This is the best part of this site. Members helping others.Thanks, it didn't take but a few minutes, but putting it in words so it makes sense took about ten minutes. I'm not sure it makes sense to everyone? If not I'll try again..
