rear turn signal question
dantep
on my 2004 chopper the left side back turn signal is loose and hanging down. works fine just loose and hanging down. I tried to figure out how I could get to it and the mechanic tried everything to find a simple way to gain access to the bolt that holds it on. Neither can find a quick way to get to it without spending a few hours. Anyone else ever have this problem or any suggestions on what I could do? thanks
RRRUFF
I don't know about the 04s but my 05 you just reach under the fender and the bolt up.
BadBrad
2005 Pitbull
Not sure about the '04 either but if you can't tighten it up by reaching under the fender, then you'll need to take off the plastic lense cover, carefully pull out the light board and you should be able to tighten from the inside. The light board is only seated by a rubber gasket surrounding the board. Use a small/micro screwdriver to pry it out. You should see a small gap in the outside edge of the board where you can place the screwdriver to begin prying. :cheers:
zipnz
Yeah, what BB said. I have an '04 Chopper, and that's exactly how you tighten it up!
cheers!
paul
RRRUFF
If you will take some WD40 on the rubber gasket before you put it back in it will just slide :D right into place.:job:
dantep
man guys thanks a ton, fixed it this morning while cleaning up the bike. took like 5 minutes. guy at the shop thought he would have to take the whole fender off and charge me a few hours labor. you guys helped a ton, thanks again. i get my transmission thing figured out and i will be happier than a puppy with two weiners!!
