avdhunter
I figured I would make a thread on this as to get other opinions and mainly to put it out in public as to hpefully be able to help others in the future. Here is a question I asked Dead .......
Got a couple questions for ya. Hopefully you can help me out. I have an 04 RB. My speedo just up and quit working. Tach and all indicator lights still work fine just the speed does nothing. Ok when turn key on it does the sweep as it should....crank up and start rolling and the needle NEVER moves. Saw where some where talking about the starting of the bike doing something to the ehc but have never had this be a problem before. Just to check I got going down the road ... pulled in clutch...turned bike off...turned key back on .... let speedo sweep ..... then release clutch and restart bike without using starter .... still no speed on speedo. So .....if the speedo can do the sweep when bike turned on should it still be ok to show speed when rolling? I have yet to pull the sensor to clean and will do when I get home form overseas. Lastly.... it is my understanding that the speedo signal goes thru the ehc but is not controlled by it....is this correct or coulod this be a sign of the ehc beginning to fail? Any and all help is appreciated bud!!!!
