chris007
hi all
i have a doug kiem chopper and the rear belt is rubbing against the rear tyre.
if i measure from the swing arm pivot to the back wheel axle the right side is 3/8 of a inch further back than the other side to make it clear the tyre. but when moving it still rubs on the tyre edge.
i have altered the alignment so both sides are the same and the belt is pressing on the tyre edge when not moving.
do i need a rear pulley spacer and if so do i have to put one on the front pulley to match as the belt is up against the out side edge of both pulleys with it set at the moment.
my bike
my bike
