new problem
jon57
alen wrench broke off in nthe rear wheel adjuster any ideals to get it out? not my day for ajusters.:bang:
bigdogtech01
Take the axle out so it takes pressue off the adjuster set screw. With the axle removed you should be able to thread the set screw all the way in so it comes out on the axle side rather than the front side. Keep in mind that you don't need that much torque on the set screw. Only 5 ft lbs at most with axle tight.
RRRUFF
What he said!:2thumbs:
