Ok, I removed both the clutch nut and the engine nut and removed the chain, engine sprocket and the clutch assembly. I inspected the gear teeth and they all seem to be in good shape. I also inspected the main shaft and was not able tomove it side to side or up and down, I was able to turn it about half in but that seemed a natural movement. am I looking at the right things and should i look for something else?
P.S
I followed instructions from the shop manual to remove these components and the instructions said to remove "the throw out bearing retaining ring and discard" should I order a replacement? or reuse the same one? The manual does not address that on the reasssembly?
thanks
