I have a 2004 chopper and the ECH went out. First the Head light, Then the horn and finally the intermittent starting issue. Purchased the Wire Plus Retro Kit, Installed it and now it won't start at all. All of the other electrical work fine. I have fuel, but I have no spark. I did install the new ignition switch from wire plus. So I had to disconnect the coil and remove it so I could grind coil cover to fit the new ignition. I connect the wires going from the ignition to the coil and a single hot wire from the old wiring. I have tested this lead and it is hot when the key is in the on position. I was told that with this coil it doesn't matter which side they are connected to as long as each post has a connection. (Positive & Ground). anyway, The starter engages and the motor turnover but it will not start. Does anyone have any suggestion. Thanks
:bang:
:bang:
