20oz:s... Some reason it's pushed out about 4oz. Been using Belray v twin transmission fluidIts just a tube, if you would turn the tranny upside down it will just run out. Did you over fill the tranny?
That seal is preventing fluid from crossing over???Also it will blow out the vent if you have a bad seal on the primary side
I see fluid sitting in that vent hole20oz:s... Some reason it's pushed out about 4oz. Been using Belray v twin transmission fluid
If the seal is bad it would pass primary oil into the transmission and just blow it all the out the vent. Oil should NOT pass between primary and transThat seal is preventing fluid from crossing over???
32oz in the primary., been watching these levels cause a few weeks ago tans fluid was low, like 8oz is all that came out. So Ive been measuring. Can transmission fluid transfer to the primary?? If the seal is leaking. Or just the one direction primary fluid to the transmission??That's the only other place for oil to come from If you didn't over fill the gear box.
What weight is that? should be 75-14020oz:s... Some reason it's pushed out about 4oz. Been using Belray v twin transmission fluid
Could go both ways of seal is bad.32oz in the primary., been watching these levels cause a few weeks ago tans fluid was low, like 8oz is all that came out. So Ive been measuring. Can transmission fluid transfer to the primary?? If the seal is leaking. Or just the one direction primary fluid to the transmission??
How do you know it's trans fluid? If levels are the same where would it come from? LolThat's the problem I'm loosing oil out the vent hole and levels are to spec. Trans oil is on my chrome down the side of the bike...
Tranny shaft bearingsI just got back from Panama Beach rally and will be checking the fluids soon I didn't want to drain until I had fluids to replace it with..
Before I left fluid levels were checked and looked good. But the vent leak has me back looking..
And when you say bearing your meaning throw out bearing??
These bearings would make noise that you could hear???Tranny shaft bearings
I thought about that with the tranny vent, air Compressor. Remove the dip stick and cover the hole with a towel and push air I to the tranny vent hole...... Thanks for the help..Also blow out the vent on the back side of the primary. If your building pressure in the primary, it will push it into the trans.
