Bad starter or worse?
Il do this tomorrow
Anyone here know how to put up video here?
Il send it via email if anyone Can help me put it up here
Yea the bike been sittning Over winter
I drove it home and parken it
No issues then
Upload it to photobucket and post the link.
Damn
With the trans cover pulled i Can turn it over manually but not a full turn
I come just shy of a full turn back and forth
Spark plugs still pulled? It will take some force to get it up and onto the next stroke.
It will spin fairly freely until you hit that one hump where you got one piston at the bottom of its travel and the next at the top. At that point you will have to give it a little extra oomph then it should go back to easy peezy again.
With spark plugs pulled there will still be a point with some resistance. It you don't have them pulled you would struggle to turn it over with just a wrench.
Svahna
plugs are pulled
I was afraid to pull to hard, afraid il bust something.
Maybe im just abit cowardly?
Guess il go out and give it some muscle.
But then again i dont have the right size wrench on there.
What size should it be? Il get one tomorrow
plugs are pulled
Nothing to brake. I can't remember what I use on that nut feel like I use a metric actually as it seemed to fit tighter than the SAE socket that is called for there.
Svahna
I cant force it to turn BUT if i turn it as far as i Can backwards (opposit way from what the engine turns when running) the starter get enough momentum to crank it With the plugg out. With plugs in it cant crank
This lead me to look at comp release
Turn out they were not pressen down after all they just didnt pull down
Quz i had a blown fuse ( i have the PDM retro kit instead of stock EHC )
But now both My battery and i are both drained so i get to continue tomorrow.
Even without compression releases. Without plugs it should turn.
When the compression releases pull down or push down doesn't matter. The down position is just a split second them pops up. If you can stick yor finger in and it moves up and down freely that is good.
I'm still thinking its a battery issue....
Svahna
Im thinking battery or weak starter
Il see what happens later today
If the engine is at the point were i cant turn it manually, the point were pistons change direction the starter should be able to crank it right?
Put in a new battery and shefired right up
But i have a noise i dont like
Could be normal, only that the primary is open?
I didnt wana close it before i knew it would crank
What you guys think?
http://s1155.photobucket.com/user/svahna/media/Starter/nn/IMG_8965.mp4.html?sort=3&o=0
Can you tell where the noise is coming from?? Seems loud but I don't know if that's the video quality?
That chain seems to be a little loose. 5/8" slack.
Readjust and try again.
