The blinker still blinks? Both?Update #2...took rear fender off left side ground wire was testing bad, really didn't see anything on that wire, red wire was pinched so I fixed that. Rested rear fender on tire and plugged in the lights. It works!!!!!! Bolt the rear fender on test again and works!!! Turn key off and put side panels on. Tested it and back to same thing! Messing around with the rear plug and where it goes to the power harness will get it to stop sometimes. When it does stop and I don't press any buttons and have a smoke, it just starts blinking again... I'm lost right now...
It will. You have a short in the rear harness.... You could put the turn signals up front on the passenger peg mounts and shorten the wires. That's what I did...I'm just worried that if I buy a new rip kit gen 1 or 2, or DOC, or the one from Curtis that it will do the same thing
Thanks for posting that, I don't have any red lights on when this happens, only when I unplug the rear or front lights, then I get the red light for that light to blink, the other thing I found when they did work correctly was the left turn signal is activated the high beam indicator blinks with it, not the headlight itself just on the speedo light, this does not happen with right turn signal. But I did unplug the speedo and tach in my testing
I'm thinking I mite have to do that, when you say "Axel's EHC" which one are you referring to?I had similar issues with mine, "ghost" issues that made no sense. Checked all the wiring and replaced the LED's same deal. Purchased and installed Axel's EHC problem solved. Just my experience.
Sent from my Pixel XL using Tapatalk
Thank you for the informationThe replacement that curtis and donna/Derek sell call either one and they will know what you need
Keep looking!! thats fine. Oil sensor sends the ground to illuminate.Another update, I called a friend to ask about checking wires if it wasn't broke but rubbed through and touching metal, he said to check with ohm meter like before but put one end to neg. battery or chasis ground and touch the pins with the other. If my meter goes to 0.00 then it's grounded. So I did this and checked a ground wire and goes to 0.00..... I am on the plug going up the backbone to the speedo/ tach I get good ground on black wire, I get no ground (meaning the meter does not go to 0.00) when checking the other wires in the plug expect the ORANGE wire. I get ground on that wire. Does anyone know if that wire is supposed to show ground? I will include a picture of the plug. Wire colors for plug are black, orange, violet, green, red, blue, brown, yellow
Haha..well that tells you problem isn't up top.I just unplugged every plug on backbone harness except key switch and it still blinks the right turn signal
Yes I only get ground on 2 black wires, just to be sure I didn't miss anything I unplugged all backbone plugs, except key, also unplugged rear light plug and still blinks...Haha..well that tells you problem isn't up top.
Try ohming out the rear harness like you did the tach. Should only ground out on the two black wires.
Sounds like might be new EHC timeYes I only get ground on 2 black wires, just to be sure I didn't miss anything I unplugged all backbone plugs, except key, also unplugged rear light plug and still blinks...
