Big Dog K-9 wont start - flashing turn signals
Pdub
2007 Big Dog. Fell over in garage sitting in Wheeldock wheelchock. Woke up to the smell of gas. picked it up and getting it ready for the gathering at Flint Oak and changing oil. Drained oil, installed scavenger oil draining device and clicked on key and turn signals flash. EHC shows solid green "Controller On" and flashing yellow "Power" I know its related to my bike falling over, but I have no idea on what to check. Any ideas on what to check?
What side did it fall on? If it was on the key ignition side I would checkout the ign switch and wires. May have jarred a wire loose, plug wires etc
Just saw the pictures I would still check it may be worth a shot. Or I wonder if the handlebar hit messing up the hand control wires?
bigkelk9
Yup if cry too.. but it won't start don't tell us much.. does it turn over? What does it do. My first thought it u flooded the carb.. but we don't know if it even turns over..
bigkelk9
Looks like the battery leaked and started corroding the ehc and other areas
Yeah if that battery leaked n e it would show good on a tender.. but if u put a meter to it would show the true voltage as well as doing a voltage drop test on it.. but again.. we don't know what the BIKE is doing
Pdub
View media item 9440 Got a nice Ping dent on the exhaust other than that I'm pretty lucky. Checked voltage on battery and its showing 13V with trickle charger on the battery and without it on a trickle charge
Pdub
In my original post, I posted what it was doing, I guess I need to post what its not doing. No turn-over, no clicking, just flashing turn signals. and lights on EHC. No sounds. Hope that helps.
Try jumping it with another battery and if you use a car battery make sure the vehicle is not running
