Headlight
Jeff Taylor
My headlight just went out I'm hoping it's just a bulb I can't get the ring off to check it the set screws on the bottom are junk
Maybe try a new alan wrench or even a metric alan wrench if you rounded them out. Maybe even a small torx screw driver, if you drill them out, sure as shit you're liable to screw up the threads
Dusty.B
Those headlight rings are tricky sometimes, once you pull it out make sure everything is nice and clean and a little wd40 on the white ring & life will be a lot easier when it comes to putting it back in place. Oh and patience lol don't force her. I dread taking the ring out of mine. Its ridiculous how tight the fit is.
The adjure doesn't screw in like a standard light. One of the reasons I love their lights.
bdm7250
Never had any issue with mine, takes about 10 minutes to R&R headlight. Also headlight stays straight without any adhesive to keep it in place. The Tejas has a set screw and what a pain in the ass it is, small set screw recessed up inside a larger hole, plus I can't see shit that small...even with my glasses.:oldbang:
cdogg556
:agree: :old2:
I don't even use the alan head set screws anymore since they stripped out, just use the one for the bezel and I treaded a bigger screw in it with a phillips head on it, still an pain in the ass to get it out, when I can I am gonna get rid of it and go with something like the wolf headlight.:old2:
Yeah, I took a quick look. I was thinking, "it must be the injectors, no, maybe its the throttle body needs a cleaning, no maybe if I hit the run button :D. Just messin with ya, the 100 degree temps couldn't have anything to do with it. it is a good looking light setup.
:oldhardlaugh:I was trying to explain to him how the bike works, even though he has one just like it, after the 3rd time, I was starting to get a migraine. I kept telling him the key is on the other side, not the side he's pointing to:oldbang::oldrant::oldhardlaugh:
Holy shit, I'm almost a marble head myself
