Help!!When I got it over there and parked it I noticed that there was steam or smoke coming out of t
I do not like the petcock on the 04 Mastiff. It labeled but does not have the positive stop position bearing to let you know you are fully in the on position or res. If a fuel filter can restrict flow then maybe a petcock not fully open can cause the same problem.
the one on mine is hard open, hard reserve, and a firm notch detent for off. no complaints here.
BadDawg Bill
I'll add my 2 cents.... I'd take out the petcock and clean the screen and blow out the gas line. Also rinse your tank out while the petcock is out. I bet some of the tank protector came off and now is embedded in your fuel bowl. When you get going hard the pieces jam up the jets and that causes your problem. Take off the bowel and blow air through all the orfaces to clean it out. Good luck
best way to drain the tank is to put the petcock on off, remove the fuel line, replace with about a 3' piece of fuel line with the other end stuffed into a gas can, and open the petcock back up. don't forget to remove the gas cap to allow it to flow, even if it is vented. then it is best to remove the tank and finish draining off the bike. handle the tank with care.
Little-Boo
I don't know where the petcock screen is but I looked at the petcock and the fuel line and there is no green anything or slimy or anything like that however inside the tank I can see the green and I can see some of that is peeled away I have a picture of that as well
If you see the tank liner peeling off is a big big NO NO. That is probably the main reason you are having fuel problems. Drain the tank and check it out. You may need to reline the tank or the problem will continue.
Carlos
And turn the petcock to RESERVE to get the most gas out
Gmutoagrsv
Carlos
I'm scared to ask. Who where and how much?
Little-Boo
You can do it yourself, just take the tank off and follow the instructions on the Kreem Tank Liner Kit. You can get that at J & P Cycles for $53.99 the kit includes
Kreem Jumbo Tank Liner Kit
• Combines to create an excellent "tank within a tank"
• Cures to a tough white skin which protects the inside of the tank from rust and corrosion
• Resists leaded and unleaded gasoline, gasohol and octane boosters
• Complete kit includes tank wash, conditioner, and liner
• Includes 16-Fluid Ounce Tank Liner, 32-Fluid Ounce Tank Prep A, and 16-Fluid Ounce tank Prep B
• For tanks up to 5 gallons
http://www.jpcycles.com/product/352...MIxqTqrK7i1QIVV7nACh3jzQmXEAYYBiABEgKGIfD_BwE
Hope that helps
Carlos
Gmutoagrsv
http://www.jpcycles.com/product/352-055?utm_term=[344004693732:*%20/%20product%20type%20=%20"vehicles%20&%20parts"%20/%20product%20type%20=%20"land%20vehicles"%20/%20product%20type%20&siteid=NB_G_PLA&product_id=352-055&adpos=1o6&creative=42616808650&device=c&matchtype=&network=s&gclid=EAIaIQobChMIxqTqrK7i1QIVV7nACh3jzQmXEAYYBiABEgKGIfD_BwE
Hope that helps
Carlos
I appreciate it very much. Any other opinions on this?
Little-Boo
Yes you can buy a new tank, never used, painted by Airbrush Ed former BDM employee that painted for them. I just happen to have a complete set of tins for a 2006 MASTIFF already painted, the Tank is lined and has never seen Gasoline. I have the Paint saver for it and a new Petcock and it lools like this.
I will post the rest following being that It won't take anymore picsIMG_0691.jpg IMG_0692.jpg IMG_0693.jpg IMG_0694.jpg IMG_0695.jpg IMG_0696.jpg IMG_0697.jpg IMG_0698.jpg IMG_0699.jpg IMG_0700.jpg
Little-Boo
Here are more. That is the best I can offer. If you are interested make me an offer. BTW this paint job cost me $3400. I just never did install this on the bike YET.
Carlos IMG_0701.jpg IMG_0702.jpg IMG_0703.jpg IMG_0704.jpg IMG_0705.jpg IMG_0706.jpg IMG_0707.jpg IMG_0708.jpg IMG_0709.jpg IMG_0710.jpg
Gmutoagrsv
Gmutoagrsv
Yet another update. I ordered a jet kit. Went to a 32 intermediate 70 main and runs good. Rode all over town tonight and no sputter. I got home and pulled the plugs. 1st cylinder was a lil on the fat side. Light soot. 2nd was still on the lean side. Is there something I missed. Making them the same burn? I'll post pics tomorrow. May be easier to help.
cdogg556
A 70 main jet? That's way lean if you ask me, I think stock is a 74 and if you have a bigger cam it gets bigger from there, I am running a 32 int and 78 main and it runs great, #2 cylinder runs hotter that #1 due to less air flow.
Gmutoagrsv
There was a 66 in when I pulled it out. I'm not sure if it makes a difference but I'm at 5500' I'm wondering if I should go down to a 31 since the front plug does have some soot.
Little-Boo
The front cylinder is always going to run a little richer because is it runs cooler than the back one since it get all the air. Yes elevation make a big difference If it runs good stay with what you have stay with it.
Carlos :moped:
Gmutoagrsv
Carlos :moped:
So that doesn't look too rich on the first one?i would be worried about the back cylinder getting lean again.
Gmutoagrsv
Carlos :moped:
So I tried the 31 instead of the 32. Plugs look a lil closer to each other. No soot. Maybe a touch lean. However the bike isn't running as well. But bouncing between the 2 jets and dropping the bowl 3 or 4 times I went from 130 miles before reserve to 93. Could I really have lost that much due dropping the bow? Or is it gonna start getting shitty mileage? As far as how it's running. Should have listened and left it alone. Lol. So I know what my next course of action is.
Gmutoagrsv
Went back up to a 32. Runs great cruising and mid throttle to about 3000-3500 then seems to fall a lil flat. No spittering just loses torque. Should I play with the main or air bleed next?
