Have a 2002 pitbull, that I bought last year w 5000 on it. Since I bought it the belt would go up again tire when backing up and would travel back n forth on front pully on hwy. Could never get to track center both ways.
After primary noise tore done n replace compensator n used 8 foot lights to center rear wheel to front...
Then checked with squares n level. All mounts, engine, trans and axle are ,+- .010 at worst.
Then w true rear wheel built trans adjusters off rear peg mounts so could push either side to true trans w wheel..
Problem is trans is the engine has no adjustment and is mounted to trans by primary..so basically the only adjustment is rear wheel...since trans is dictated by engine n primary.
That's fucked up for obvious reasons..
It "appears" that the rear axle is properly spaced but who knows ..unable to find formula BD used to set up spacers or any other specs. Belt has always found home on shifter side if front pully.
Sent from my SM-J737T1 using Tapatalk
