68Firebird
I have a 2010 Big Dog bagger all original no modifications. I put a new battery on it and it doesn’t want to start. When I go to start it all the gauges work turn signals except when I press the run button I don’t hear the fuel pump. I hear the front relay on the right side of the motorcycle shutter, it will not try to crank. I tried to switch the relays from front to back and still doe’s the same thing. Can someone offer some advice on what to check next… also the gauge will say hi rpm while front relay shutters. Thank you
