Spike Filter and Tuning
Installed a spike filter on my 08 k-9. Idles fine just cuts out when I give full throttle in lower gears. Wondering if that is a jetting or accelerator pump adjustment.
Mikeinjersey
Start with the basic adjustments and then if you can't get it dialed in look into changing the jets which is a little more involved. If your only issue is what you described the accelerator pump adj is a likely suspect. In this guide step # 11 refers to what mleach72 is asking.
41bigdawg
Let the Big Dawg eat !
My experience with the Spike before I sold it and went with a dual runner was frustrating. Never could get it dialed in perfect, I put in a #60 on the air bleed jet and had to point the spike straight up to get it to stop cutting out on accel, spent a lot of time trying to tune it and was never happy so I went with the dual runner and never had a problem. I know some don't have problems with them, just my experience.
francoblay1
The Spaniard
Yup! Must Do.
Did you remove the auxiliary vent plug?
If the S&S teardrop air cleaner is being replaced with an aftermarket air cleaner, be sure to remove the auxiliary bowl vent screw (#14). (as stated in the tuning guide posted by [B]Mikeinjersey[/B])
Yup! Must Do.
:chopper:
willywill4765
I have a fuel injected bike was wondering if anybody has used the trask high flow air filter. It's the one that you can see through it and it's round.
Sent from my Pixel 3 XL using Tapatalk
mleach72
A couple guys have installed those type of ac's. I think @Mastiff Rider64 was one. They are meant for harley carbs and efi, so you need an adapter plate. One guy drilled the backing plate to make it work. I forget who that was.
