billconroy
I changed my righthand control board on the handlebars of my 05 ridgeback and break lights don't work , still work with my foot break
Did they work before you changed the board? Did you move or replace the sensor when you changed the board?I changed my righthand control board on the handlebars of my 05 ridgeback and break lights don't work , still work with my foot break
I changed the board and sensor but I'm not sure what position I should put the sensor in , now I just ran it back down the hole in the handlebarI changed my righthand control board on the handlebars of my 05 ridgeback and break lights don't work , still work with my foot break
Turn the key on. Pull the brake lever until you feel pressure, then slide the sensor into the hole until the brake lights come on. Then tighten the set screw.I changed the board and sensor but I'm not sure what position I should put the sensor in , now I just ran it back down the hole in the handlebar
I'll do thatTurn the key on. Pull the brake lever until you feel pressure, then slide the sensor into the hole until the brake lights come on. Then tighten the set screw.
Do u use the solder or the connector type of the reed sensor?I changed the board and sensor but I'm not sure what position I should put the sensor in , now I just ran it back down the hole in the handlebar
I did what you suggested , it went in a little, how far should the sencer go inAnd there you go.
How do you get the sensor out of the control? The connector on mine broke and I need to replace it. Looks like I’m going to have to remove and solder it.I changed my righthand control board on the handlebars of my 05 ridgeback and break lights don't work , still work with my foot break
What problems are you having?That is part of the problem I'm having now
It came out when I had a little accident
And I'm not sure how to install it correctly
I know it works, I touched with a magnet
And my breaklights worked
