Squeak coming through the exhaust. I’m at a loss
mleach72
I may have an answer to this "chirping" sound. I also may have answer to the great mystery of the purpose of the fiber washers under the coil cover. I just replaced the spark plug wires on my bike. It's a lot easier to change the plug wires if you remove the coil cover from the engine. After I did this and put everything back together, I noticed I was getting a chirping sound much like the OP. I couldn't figure out what it was. Then it hit me. I forgot to put the fiber washers back in. I took it apart and put the washers back in. Chirp has now disappeared. Maybe that is the purpose of those mysterious fiber washers.
Twistedspoke100
05 Mastiff
Strange! I will look to see if they are in there. I have pretty much have given up on the chirp. I have tried torque cones, they made it go away almost completely but at the cost of 10 HP so they were taken out.
mleach72
I know you just had some engine work done by John. You may want to ask whoever put your engine together if they remember putting the fiber washers in. It may save you some trouble. Unfortunately for us guys with the prostreet bikes, removing the coil cover requires removing the tank. For you and me, just the left side tank.
Twistedspoke100
05 Mastiff
I had the coil cover off myself a couple a weeks ago because of a snapped top mount bolt. I did forget to put them in, luckily I caught it before I put the tank back on but now I am wondering if I put them on the right side of the coil? I will be posting a update about the final build! Bike performs better than anticipated.
Twistedspoke100
05 Mastiff
I will say I went up 2 jet sizes after the final Dyno and the squeak now almost entirely goes away when its hot. Its still there but very minor. I have spoke to a few techs now that have said they have heard this before, but have know idea what to do to make it go away. One guy said he used torque cones and that did work pretty good but killed the performance.
2004BDDt
I have a chirp when letting off in gear. Sounds like steel to steel. I have tightened the two front motor mounts on the bottom and the two from the heads to the frame. I only used a 3/8 rachet; should I tighten more? Thanks
