Good call, but is this knocking or tapping? Get out a stethescope and try to pin point the origin of the noise.the lower rocker box gasket installs a certain side up. otherwise it blocks off passages.
just saying.
I haven't got everything back together yet (heads rebuilt, new piston set, push rods, and cam) to check. I am hoping that everything will be fine with doing this. :bang:Good call, but is this knocking or tapping? Get out a stethescope and try to pin point the origin of the noise.
I'm too lazy to go back and read again but I think snyper said he found more parts of the valve guide in the other cylinder that would have been making some noise.What damage did you find that would cause the knock?
Like John stated, it hard to determine without actually hearing.
Seeing that you said that you bent the valve in a Z pattern, that's a pretty hard hit on the valve and "valve train" components. I'd be sure to check the rockers,push rods, lifters and also cam.
After that, if the noise is still there, I'd suggest pulling it back down and thoroughly checking out the cylinder that the valve was bent. Looking at the rod once again, rod & crank bearings, wrist pin and the piston skirt (in the wrist pin area) for damage.
But I'm leaning towards more valve train damage, the bottom end is much stronger than the rest of the valve train components.
Hope this helps! Good Luck! :2thumbs:
dead![]()
Hey John, did you here that?Hey Dead,
If you started all your replies with, "Like John stated", no one would ever question your intelligence.
:roll::roll::roll::roll::roll::roll::roll::roll:
Snypr,
Did you say they got there via intake manifold? I would think that would be a hard way to go since there is always pressure pulling into the cylinder, not the other way around, but someone else would have to say for sure. This was a topic when I first joined this site. John Sachs explained to me how parts of valve guide can break off and make their way back into the oil system........I believe that's what he was saying.........so you may want to check and make sure that all the pieces of your valve guide have been cleaned out before firing that mother back up.![]()
I got S&S to warranty the pistons, rings, steel collar, valve, and valve guide. I ended up putting Mahle stroker pistons ($100 Ebay) in which have a .053 higher compression height and used Cometic gaskets (.010 base, .027 head, .020 rocker base) (Thanks Toobaddcustoms) thus zero decking without any machine work. I also installed a Vthunder .608 cam ($29 Ebay), thunderslide in the carb and a hypercharger. The bike runs awesome!
Sorry, sold on ebay!S&S warranty with new parts?
still have the pistons?
Took the rockers off and put in new o-rings. No leaks! However, now my oil pressure is 35 at idle and 50 at mid power? Next step I guess is as you and RRUFF stated to check breather lines. I never removed check valve so I don't think that is the issue. :bang:Check both of your crankcase breather lines for blockage and check your breather line check valve. If there is too much pressure inside of the motor causing it to leak, I'd start there! :2thumbs:
Hell, who knows, maybe some more trash from the previous damage.
dead![]()
That's crank case pressure, not good. It's not venting somewhere!Also, after shutting down the motor and checking the oil. Oil blew out the fill neck as soon as the o-ring cleared the threads?
Much appreciated advice! Will do. I will post the outcome.That's crank case pressure, not good. It's not venting somewhere!
If there is trash in the check valve it won't operate properly! So it could be your problem.
At this point, after tearing up parts of the motor, don't ever count anything out, parts trash could be anywhere! :nono:
If the oil pressure is that high when cold it's OK.
But if it's that high at idle after the motor is hot. I'd say you might want to check out a few things that could be blocked causing it to be that high.
dead![]()
When you did the top end did you ensure there the check valve on the rear breather hose went back in properly?Much appreciated advice! Will do. I will post the outcome.
