What I'm reading, I'm going to explain what you said and add to it:
I unhooked the VR wire to the battery.
I started the bike and with the volt meter set at 20v, it spiked to 58v? (I assume you are reading the volt meter, right?)
I ran the bike 15 minutes at idle; so being air cooled, is stationary; the bike heats up, the pipes glow, I know, I know... now.
I caused the bike to run at a total loss [no charge in play] so I know there is no spike at the fuse from the VR.
Plus:
I could ride with all connected, and within 15 minutes, she dies.
I can remove the VR, let it sit and still the bike cuts off within 15 minutes.
I have no problems with the processor because it continues to refire.
I pull out the wallet and ask the fold, do I throw the price of a sensor at it or the larger part being the processor.
I can for sure have a new sensor in play on the cheap, because if it still cuts out on the first test, gulp.
I then ask the wallet one more time, do we buy a boat or a processor?
So back to the 58... WATT or where was this number if the meter is set at 20v? Or was it set at 200v, next one up meter wise?
Or did you see 5.8v once you started the engine to draw the volts down, and that was what you saw and it came back up to 13v+?
I can't make this scenario work... The stator is loose? No. The spike is a constant? You'd have to start it up and have that 58 repeat.
No loose stator or rotor, or all those rides your battery has taken, would have gone down if the AC acted up but no.
Did you hear a click at the fuse this time with VR not connected?
Plus:
