First off, just because it says 310cca on the battery, doesn't mean it is. We recommend the Deka battery for these bikes, and clean your starter solenoid contacts often.I have an 04 frame with the 107 EFI, can I bypass the thunderheart system. Has no fire to the plugs and the coil tested good? It’s a Mastiff. But I’m not sure how to bypass it. But it’s driving me crazy don’t know exactly what to do. My 310cca isn’t strong but it will turn over good time , enough to start the bike but no spark
As for your ignition module, we don't see them go bad very often. More than likely it's the cam sensor in the nose cone, or a broken wire between there and the module.
