The red went to powerI tried to post earlier but when I installed the wire plus in my 07 efi Bulldog I had the low fuel light staying on all the time in a dim mode.after a bunch of emails back and forth withe the manufacturer they came up with an in line resistor that hooked to the grey and white wires going to the lights. I can't remember were the red wire tied in.I have looked for the schematic they sent but haven't had any luck.it probably ended up in Montana with the bike when I sold it.
I'm confused why you tied this to a power circuit, as opposed to just having the resister inline.Hi Fourbar,
My BD dealer don´t know about a ver. 2 schematic. It might be a different software but basically the same schematic.
Eric, your idea with a not working tester was rightThe tester does not work with the Low Fuel LED. We just checked the Low Fuel led in combination with my EHC58E at a bike. A 180 Ohm / 1 Watt resistor will help to switch off the led if the tank is full. This might work for the other harness replacement solutions what are on the market. I already added it in my EHC in order that there is no additional resistor required. I attach the EFI schematic with a handmade drawing. The resistor is hanging between B32 and B40 and you might can put it in the B-connector or somewhere beside of the tach board.
We tested several resistances and the led was almost off with a 180 Ohm value. When you increase the resistor then the led will start to glow brighter. A value below 180 Ohm will result that the led will not glow. However a lower resistor value will increase the current through the temp sensor what will might result in a temperatur increase of the sensor and a wrong display. So, I think, the 180 Ohm is a good value to start...
I hope it helps!
All the best!
Axel
I think the thermister gets warm and measures the increase in temp as fuel goes down?I'm confused why you tied this to a power circuit, as opposed to just having the resister inline.
Can you explain?
I tend to agree. It perplexes me. Why would the fuel be a different temp than the air? Especially in a condition like sitting overnight in the garage.Seems like the thermistor would work on a temp differential
More so than a set temp. These bike run in weather extremes frim below freezing to over a 100.
I'm also not going to ask why you are sticking your hand in a bucket of gas...lolEver stick your hand in a bucket of gas. It's always cooler feeling than the air.don't ask me why
Makes sense to me!Google thermistor and get your hands around it.then explain it to the rest of us![]()
Well Kevin I copied that from google. I'm not that smaht..hahaholy crap! you guys know your shit! how the hell do you know something like that!?![]()
Ker and I had a chat today. I've been doing my research today I've now gotten my hands around the terrible install on the PDM and I got some other electrical information I need to post.still you know more than me! I'm an electrical idiot tho I'm very mecahnicaly inclined electronics is not my forte and Ker knows his shit too with all that kind of stuff
Cool!I got mine in the mail today. Will try and get it on the bike this weekend. Looks likes rain for the next 4 or 5 days. So maybe not??
Thanks Alex
View attachment 32029 View attachment 32031
A guy with a name like that is just going to keep things rolling, no pun intendedAll I've got to say is Axel is one smart dude! My fathers name was Axel and he was a genius too. I can't believe someone could spend this much time on a project and see it through. A lot more patience than I have. Go for it Axel and I hope you make a lot of $$$$.
That's old school Buddy, and an old paint brush scrubbed the crud awayNot reccommending it but it does clean greasy parts quickly.
