Tru Dat, not to mention it would leave your hands whiteWhen I was a kid on the farm diesel and gas were the go to cheap cleaners. This shit will kill you today![]()
Ya, he did some amazing things in his life too bad I got so few of his talents and wisdom....Soooo, your father was a genius![]()
Thanks. Ignore these hijackers, this isn't the thread for that haha.Hm, I haven´t read the last page of the thread. Sometimes it makes sense to read the thread until the end before posting... Eric you already explained very good the function of the thermistor, Great
I already changed the layout a bit in the EHC. For the new version there is no need for an additional fuse. This is except of the EFI version. In the EFI version I still provide an external fuse, cause I have the internal current limit board not ready yet for the EFI version.
All the best!
Axel
I think the breaker is too slow agreed.Hi Eric,
Sorry, I have not read it correct due to my lousy englisch...
In my opinion is the fuse just a protection of the battery in case of fails of the VR. Sometimes a faulty VR makes a short circuit from the battery side to ground and a fuse will protect the cables to the battery against fire. A breaker also might work but is usually far slower. I have breakers from Carling in an other project in use and they need a pretty long time to switch off in case of over current. Just feel free to look at
http://www.mouser.com/ds/2/65/C1005B from Thermal_Catalog-369668.pdf
You can see at page 2 that they need about 1 - 10 seconds to switch off when 300 % overload is happen. However, The fuse or the breaker will not protect the battery against overcharging.
All the best!
Axel
TiceyI heard people talking about indicator lights. On the board under the seat, the red one is steady on when I hit run, is that normal? Never changes.
Sent from my GT-P3113 using Tapatalk
The Voltage Regulator on these engines are supposed to be Max 32Amps (some have installed a 40AMP).Hi Eric,
I don´t know if the alternator can handle 30 Ampere if the VR will fail. The average current consumption of a bike is somewhere between 6 - 15 Ampere if the starter motor is not in use. If the charge current is in this case somewhere below 15 Ampere then the 30 Ampere fuse makes not much sens
e and the alternator will cook the battery. Maybe I´m wrong. What is your opinion?
All the best!
Axel
Agreed VR should regulate the current back and the breaker was there incase VR crapped and this is what I thought too.......BUTIt is the voltage regulators job to prevent from overcharging the battery.
The fuse/breaker is only there in the event that the regulator fails/shorts such that current is unregulated and you get the full ~50-100 amps and cause a fire/meltdown.
