I need your help. 07 bulldog wont idle.
johnle712
Sounds like it might be the Throttle Position Sensor either out of adjustment or bad. Not sure what ECM you have on that bike but if it is the S&S you can pull the trouble codes with Pro Tune Software and that will tell you where the issue lies.
You are spot on. Could you show how to test tps and how to adjust it?
TreeGuru
I'm just hear for the beers, I never had the privilege of owning an EFI. When you replaced the pump, regulator and filter did you notice a crack in the housing that holds the regulator that would cause a leak in your tank?
