KaptinAmerika
That's what it takes sometimes.Thanks Curtis for taking the time and helping me out. Not sure what I'm going to do now. I'll regroup and start again.
Oh that is a genII unit it's got the EHC connector, somehow I missed that earlier. Either way it doesn't matter now.It's gray with 8 wires. So here is my plan of attack. From what I know of this system, they use the existing wiring harness up front. That connector gets plugged into the new one. To me I should have power down to the new harness. I am going to disconnect that piece (see pic) and use a test light to check for power from the run/start switch. Since this unit was installed from the dealer, I have no diagrams of how power is fed through. So my question is which pin should I check for power from the run/start switch? If it shows no power, then I guess it's time to check upstream.
You have no power to the coil because the ignition module has no power.Are these connections right? I pulled the tank off again. I was looking at them and noticed the color code didn't match up. So the picture shows how it's plugged in now. The empty plug, has the correct color code. I went ahead and switched them. Everything works the same. So should I leave it as it is or change it so the wires match?
Also I have no power to the coil when I turn the key on. Should I?
I stated "which sends power to the crank sensor" which is wrong. The crank sensor creates it's own AC current.Well if the run button powers the module, then the module powers the coil, and the run switch is good, then there has to be a problem in the wiring that that have all taped up. Looks like all the grounds are in one location taped in a bundle.
