Front Runner
Gas, those pipes are sweet !!!
Thanks for the heads up:2thumbs: . I'm still in the market for some new pipes. Don't know exactly what I'm gonna do. I may have to go custom. Need to be different.Hello, Oscar Maldonado I don't want to cause a panic but the ultra slashed pipes that you are going to install on your bike may cause the stud on the rear cylinder to break. They are free floating and the vibration from the engine could cause the stud to break.I have a short set of pipes on my chopper and the vibration caused a stud on the rear cylinder of mine to break. I replaced the stud and made a short bracket running from the bolt that holds the pipes together to the transmission. No problems now... hope this info. will help
Salty,Cobra,
I have a set on my 02 Pitbull. Just ordered the Softail ones and reversed the bracket in order to fit the 250 tire. No problems with them and they have been on since late 03.
The problem is that Big House and I think Seat already had this idea...I am hoping you all get custom pipes sao I will have the only BR pipes and can save some dough. my thoughts.![]()
They are Vance & Hines. Got them when they were first out and just ordered them for a softail (pre-99). You will need a custom bracked. I was able to bolt mine on the inside of the frame mounts with some adjustment to the supplied bracket.Salty,
Are those Vance & Hines? Or some other make? I called V&H and they said they had nothing for a 2003 BDM Chopper.
Thanks for the info.
It's funny. I have the 2003 BDM Chopper and I also have a 2002 Harley Heritage Classic Softail. The mounting bungs on the frame on each bike are 2" apart. Rough measurement from the frame mount to the bolts on the Cylinder head are very close, if not the same. I'm thinking that any exhaust for a Harley Softail 2002 may work on the Chopper. Maybe the studs are different measurements, I haven't checked that yet.They are Vance & Hines. Got them when they were first out and just ordered them for a softail (pre-99). You will need a custom bracked. I was able to bolt mine on the inside of the frame mounts with some adjustment to the supplied bracket.
Not too good. I went to Blowes and picked up some supplied to mirror yours. I got some 1' shrink tube and put it around the 1 inch wide steel flange I made so it would not mark the frame. When I went to attach the C clamp to the frame I saw there is not enough room inbetween the oil tank and the motor mount to do it. I have the piece from the exhaust to the frame. Now I just need to reconfigure how I'm going to mount it.Looking good there Mario, how did you make out with the bracket?
Yea man... I like the V&H BR but this pipe iz GANGSTA!!!!!![]()
DAMN!!!!
That's the shit right there! :2thumbs:
Thanks man, I love the black pipes. They never get dirty and they break up the bike a little bit. I can't tell you how many times I've bottomed out those pipes too, and since they're black all you gotta do is hammer them back into shape and hit em with some high-temp paint. viola, good as new.Nice Pipes Gear!
