Roaming Wolf
Hi
Big Dog K-9 2018, 5,000 miles only. While I was riding today the red light came on again. It is riding fine when I twist the throttle, however it is very low on idle to the point that it stalls. When idling the RPM is about 600-700. The lights of the speedometer are blinking like a Christmas tree. Connected to the computer. It showed O2 sensors. Switched off, started again. Worked OK for a couple of minutes util I twisted the throttle. Showed a bunch of mistakes then, mostly related to air temperature.
O2 sensors are new, gas pump is new, ignition coil is new, spark plugs and spark wires are new. Both rocker cover gaskets are new, clutch set is new, right shock started leaking, changed the repair kit. New battery, new voltage regulator. I use it only 2-3 days a week for a light ride as I have my old and reliable FXDWG.
Anyone has any idea what might be wrong?
This bike really pisses off. The quality is shit. I do get that it is a sensor problem and Big Dog do not produce them, just put everything together, but why is it always happening to this bike. My other 2 Harleys 2012 and 2020 have never ever given me such a pin in the ass, and they are using the same sensors I believe.
