Yep did that last night checked the chain it was tight. But did not put it in gear, Can I pull the clutch leaver spin the tire and then check the chain. Just want to make sure I check all areas of the chain.
No take your spark plugs out, put the transmission in top gear (6th) and then turn the rear tire, it will move hard because you will be turning the motor over and also will be turning the primary chain. Turn the rear wheel a 1/4 turn at a time till you find the loose and tight spots.
Spec. is COLD 5/8"-7/8" slack, slight downward force and then upward to get your total measurement.
Also while you are turning the rear wheel, listen to see if you have some noises coming from the transmission or even the drive pulley off your main drive gear.
In order to check your front drive sprocket nut and clutch hub nut you need to remove your primary cover. Once you have the cover off grab hold of the clutch basket and see if it moves in and out or up and down at all, if it has any play your nut is loose. Even if it does not move, just to make sure remove the throwout bearing via the retainer clip (C-clip) or via the 4 , 1/2" drive 5/16" bolts that hold your clutch spring and pressure plate on. You will see the hub nut under that. It is a metric drive, 32mm. The front nut is 1 5/16" drive.
If the nut did loosen up you should check to make sure the inner hub surface is still ok, the surface that rides against the hub shim (or if no shim, will be against the Main shaft bearing inner race) If it has any edge, wear, you should replace it. If your bike has the old style clutch hub shim (more than likely it does)(or it may not have one at all) replace it with the new hardened one.
Also keep in mind if the hub nut did loosen up most likely the Main shaft walked over and is causing your gear set to be misaligned. You need to make sure you torque that hub nut to at least 100ft lbs during reassembly. Front nut is 160ft lbs. I also use RED locktite on the two nuts, and don't be shy with it, if you use only one little drop it will loosen back up again.
Stay away from that Amsoil too. It will make your clutch more apt to slip. Just use regular primary oil. Amsoil is known to cause lifter problems in your motor, so stay away from using it in your bike. Use Mobile 1, Spectro, Castrol, or Bel Ray.
If you feel you are a bit overwhelmed during your tear down feel free to ask more questions, or PM me and I can give you my number to call. There are a few specs to look at if you want to measure your clutch plates as long as you have it all apart.
Good luck to you and hope you figure it out.:up:
