Would you happen to have a spare EHC for a 2007 K9?Docs esc is available from his website deadonecustoms.com & t he rip kit I think Curtis has at wildsteedworx.com both are less than 800 I believe. & you can find some stock ehcs floating around if you just want to replace it with a stock one. I've got 70k miles on my stock ehc in our ridgeback. If you call either of those guys they will help you out with getting back up and running!
I definitely will have interest!Well if it's 300.00 or LESS you will have some interest there!
Yes, it will be below 300,-. It´s almost similar to my D-Box ( http://www.elektronikbox.de/ebox_d_uk.xhtml ) what cost 179,- Euro. This is about 205,- USD. I attach the manual of the D - Box for your info. The EHC replacement just have 2 additional highside switches and the 2 d-sub connectors plus a few additional parts compare to the D what cost not the world. The microcontroller and the software are the same.
However, pls. give me 2 weeks more for finish and testing everything before I´ll feel that everything is fine.
All the best!
Axel
Check THIS out too.I have a 09 Big Dog K9, The shop is saying that i need to replace my wireing harness (ECH).I m understanding this is common with Big Dog motorcycles.My problem is I dont know where to buy the replacement parts.they are saying they can get me the complete wiring harness for 800 dollars.Will someone please tell me where I can get the correct DOCs, ESC or RIP kit that I need for my bike on line. thank you !
Hmm I'll check when I get back in town next weekHi Scott,
Thanks for the info. Do you have a schematic of the wiring from your bike? The female connectors are availabe without problems and an change against the other connetors is no problem if the wiring is compatible and there is no motor control inside. Pls. send it to info@elektronikbox.de if available.
All the best!
Axel
