You need to leak down these engines when they are really warmed up good. Leaking a cold engine typically will work fine, that's if the block, which is your cylinders have a structure that is stable. In this case they are not and therefor your test results can drastically change from cold to hot. With that said, if you do not have a barometer to go by, a good engine tested hot, then you're pissing in the wind because the only comparison you might make is that of a completely different design.
Building engines for 33 years, i'll take a good stab at what is considered "good" based upon understanding these engines.
18 to 25 percent when really warmed up and hot. I'd kinda be surprised if they leak like a good v8 engine which is around 10-12. Also do remember, that if the engine is oiling, then that will give you a false indication because the oil will provide for a false seal.
When doing this leak procedure, and getting it hot, make sure that vent line does not go back to the air filter or manifold area, because if the rings and cylinder finish are questionable, then it will have excessive crankcase pressures and it will send oil up and in that line. Some seems to be normal based upon the poor engineering of the oil pump scavenge stage and ring choice by S&S.
