Electrical problem
bdm7250
Maybe the snarky back and forth turned him off. Or, maybe he is working on the problem and will get back if he needs more help. I don't understand why these kind of condescending comments are necessary for some.
I would say humorous rather than condescending... just my opinion though..
04boxerman
I'm still here lol, I haven't been able to get back to it, it was rain, I've been working 6 days a week so have little time to look at it, I appreciate all the help, I'm not a drive by person, just don't have a lot of time . When I'm able to get back to it I will look at all the suggestions. Sorry I haven't been back on .
bdm7250
You keep your scoot inside, don't you?
04boxerman
No I can't keep it inside, didn't have a cover on it, and it rained pretty hard, hopefully it's just water, will be back in town tomorrow so I'll have time to look at it.
04boxerman
Well I tried all the suggestions, speedometer is dry, pcb switches are dry, I have looked for fuses and can't find any, I am kinda lost, I can't find any water intrusion, at this point I'm thinking the ehc.
SEAL-rider
A BD in the rain without a cover will be a cranky if not caustic girlfriend. You have to keep her dry. You will be constantly chasing electrical issues. "Just water" is a big issue. At least Saran Wrap the bar controls and ignition area. But, it really demands a waterproof environment. Even the fork oil will become contaminated and fork issues will follow.
Bob Whitford
How can you tell if its the EHC ? I have an 09 Coyote, rode fine yesterday about 50 miles and 15 miles from home lost all electrical power. The battery is good for sure.
Big D Florida
What other symptoms, besides shutting down, did your bike exhibit? Lights ? Horn ? is anything coming on when you turn the ignition on ? Are there any lights on the EHC ?
Start your troubleshooting at the battery check voltage key-off and key-on. Then check while hitting the starter, with key-on..Let us know what your readings are.
Then fusing/breakers, then wiring.
Bob Whitford
There are no lights on the EHC. Battery voltage is 12.8 V with key on or off. Didn't check voltage when hitting start as nothing comes on at all. don't have any fuses that I know of did have power to the one breaker I know of. no power to ignition at all
Big D Florida
Voltage is a tad low, Try operating the breaker off, then back on. See if you get lights, and power to ignition.
Bob Whitford
Just replaced the breaker last month, new one doesn't have the reset button. but I could bypass with a fuse. Battery was a tad low but I sat on the side of the road for several hours waiting on a ride home. I'll put the EHC back in and try bypassing the breaker
