Axel
Hi,
Curtis suggested me to make an EHC for the 2003 and earlier models. However, it´s winter time and not the right weather for riding. I know, that the 2003 EHC is absolutely not a big business but I like the bikes, even when they use the bulky Harley style handle bar switches. So, I have looked to the schematics and have start with the project. The 2003 EHc is easier compare to the other EHC, cause some signals are just pass the connectors and don´t affect the control. The wiring of the older bikes is more traditional. Additional the connectors are much better compare to the computer con´s what were used at the newer EHC. I ordered some connectors from Mouser and started the layout. I hope to get the parts in the same housing, what I use for the other EHC. Here is the "first shot" of the layout without the solder paths yet:
I don´t know if the space between the con´s is enough and will continue when I got the con´s delivered.
My first questions are: Does somebody have a high res. pic of the original 2003 EHC? What kind of connector is the 8 pin J5? I have found only low res pics, where I can not identify the 8 pin. Thanks a lot in advance!
All the best!
Axel
All the best!
Axel
