Gregory Kettner said:
Thanks for taking the time and commenting!
When this gets up and going correctly I will use your suggested techniques to get in neutral coming up to a stop. I did look at the throwout bearing which is mounted on the pressure plate. It is not pressed in which surprise me. There is no FreePlay in the bearing itself but as the bearing sits in the pressure plate with a locking keeper there is play in that part of it. That is just a design I suppose and that play could be taking out with the pushrod and adjusting it. I’m gonna go ahead and order new clutch pad pack of 12 don’t know if I’m going to order a pressure plate or the spring plate though.
Maybe I should pick up the last two parts I mentioned because, I tried adjusting the cable in full throw distance or clutch fully engaged. By turning the pushrod up against the throwout bearing tightening the nut then adjusting all slack out of clutch cable and still could not roll the bike forward or back in gear without the motor running?
