brake lights
G-Dawg
Brake lights suddenly stopped working. Was thinking it was a brake switch but when neither front or rear work, hard to imagine both switches going out at the same time. Any ideas where to look for the issue?
knothead
Second Chance Customs
Rear brake switch on the rear caliper is probably bad...could be a broke wire on it also.. does the running lights work?
G-Dawg
Running lights and signal lights work. If it is the rear brake switch, why would the front brake not still work?
I did. Wire seems to be intact. Any suggestions on where to get a switch from?
HDM has them. They should be shipping parts out on Monday.
Jersey Big Mike
100K mile club
Just use a multimeter to check the switch.
You could also short the wires together if you trace it back to the jst connector.
Do turn signals still work? Check the bulbs/leds.
