Running lights and signal lights work. If it is the rear brake switch, why would the front brake not still work?Rear brake switch on the rear caliper is probably bad...could be a broke wire on it also.. does the running lights work?
Signal comes from the front and rear brakes go to the rear brake switch to make the brake lights come onRunning lights and signal lights work. If it is the rear brake switch, why would the front brake not still work?
Check it it may just have a broke wire.Mahalo, I will try replacing the rear switch. I appreciate the feedback.
I did. Wire seems to be intact. Any suggestions on where to get a switch from?Check it it may just have a broke wire.
HDM has them. They should be shipping parts out on Monday.I did. Wire seems to be intact. Any suggestions on where to get a switch from?
No. Replaced it a few years ago with Dead One Custons EHC.Does it have stock EHC?
Just use a multimeter to check the switch.I did. Wire seems to be intact. Any suggestions on where to get a switch from?
If you too are having issues, its best to start a New thread so you can get the help you need. JsTurn signals work. And yes Led.
