MossBerg590
Looks real nice. One question,
How does it mount?
How does it mount?
Hurry up, I am waiting...Yes, I forgot: There are 2 x 6mm threaded nuts in the botton side. Hovwever, the screw distance is not the same compare to the original due to the smaller size of the box. The screw distance is 79mm. I choosed it cause I want to clamp the board holder inside between threaded nut and wall, what fit exact between it.
You can see inside the white acyl glue what close the hole against the resin.
All the best!
Axel
Call Curtis or whoever ya bought it fromI just received my RIP replacement for the WirePlus ECM (which lasted less that 2 yrs).
So...like i removed all wires from the Chopper back bone. And I don't see how I can safely get the
new RIP connectors and cable into this hollow frame w/o damaging the connectors. This is like trying the get 10lbs into a 1lb baggy!
I must be missing some secret. Any suggesitons?
Much thanks
email me wsworx@gmail.comI just received my RIP replacement for the WirePlus ECM (which lasted less that 2 yrs).
Much thanks
That don't sound good, wonder what happened to that?I just received my RIP replacement for the WirePlus ECM (which lasted less that 2 yrs).
Much thanks
WSW (RIP II, an updated EHC) and DOC's ESC. I don't have anything on Axel's replacement, may want to PM him.Where can I buy an EHC replacement? johnerrigo@hotmail.com
Awesome! Good job Axel....Just an update:
The new potting compound is much better (...and hell expensive as well). There was no red color in the EHC after 3 hours on the shaker. So, there was no need to destroy the EHC
However, I just fix and test the first small serie. I will test the EFI version with "my local dealer" on Saturday and I promised to give some EHC to forum members for a reduced price. I´ll contact these members this Sunday or Monday when everything is tested and fine.
Thanks to all for the comments, suggestions and the very friendly support. You helped me to finish the EHC devices. By the way, I already are "in love" to BD and will save my money for a Ridgeback...
All the best and let´s keep in touch!
Axel
