Cool I agree install failure is common. I'm sure you have seen a Wire Plus unit that has two separate modules there failure rate was quite high due to the installation process. Cutting and soldering 50 wires one by one. I've had mine trouble free for 5 years but it was a pain and see where people mess up.Hi Erik,
The failure rate of my D-Box is about 10 percent while the installation and about 1 percent when ready installed. However, 90 % of the failures are customer problems while the installation and could solve by phone or mail. That´s why I prefer to sell my boxes to a few distributors with technical background knowledge and a good telephone support. However, the 1 % sounds good at the first view but here are many custom bike owners around in Europe who drive a few hundred miles per year. So, even the worst electronic design might work for a couple of years in this case. I still have sometimes returns from my old C-Box what I made between 2008 and early 2009. This box was my first "experiment" in this area. I still change these old devices against the H-Box for free, even after 7 years, cause I can not let my costomer hang in the rain. The warranty time is 2 years normaly. Just feel free to search "Elektronikbox" in several European custom bike internet foren. I believe, my customer support is not so bad. The comments in the foren speak for themself and it´s better than any stupid advertisement.
Erik, you know my opinion about the connectors. It was good intending from BD to give the customer the opportunity to change the EHC in a couple of minutes in case of problems but you see the result. if you would like to do a good job on your bike then better buy a D-Box or something else with better connectors, rip parts of the old harness and invest 1 day work with the installation together with an experienced bike technican and you might have fun for many years without any problems if you do the wiring in a professional way. A bike control is absolute not rocket science.
By the way, I wonder that BD had changed the connectors in the late 2008. The frame from the cable connectors covers the EHC connectors what will prevent the EHC connectors better against water compare to the older con´s. The rest of the schematic is almost the same with only a few minor differences. Why not earlier? What is your opinion about?
All the best!
Axel
I was wondering if any of the components you used would be considered of better quality or sturdier than the original EHC ? But seems like for the most part they are the same?
Anyways thanks for it. I wish I could try it but both my dogs have different units so I no longer have the harness. Got a Wire Plus in one and a PDM in the other.
Enjoy your time off over the next few weeks you deserve it!
