Here is a 2008 post from Forum Member Loafington.
Here is the skinny from S&S regarding the case drain plug. This is an email message. The message actually starts at the bottom and the most recent reply is at the top.
As far as I can see, this disputed bullshit myth of having to prime your pump if the case drain plug is removed, is well, BUSTED according to S&S, the maker of the S&S 117" engine.
If you get more that a quart of oil out of that plug it would mean that your check ball, in the oil pump, is not seated correctly. You do not need to re-prime your pump.
Thanks,
S&S Tech
Sent: Friday, July 25, 2008 2:31 AM
To: Glick Brent
Subject: RE: S&S
If that plug is removed, and old oil drained from the case, does the oil pump lose it's prime and need re-priming after the oil is drained from the case?
Subject: S&S
Date: Thu, 24 Jul 2008 20:53:40 -0500
bglick@sscycle.com
That is a drain for the crank case it is not necessary to remove that plug for every oil change but if you want to get any oil out of the case that my be left behind that can be removed. It is a pipe plug thread so there is no real torque spec (just use common sense when tightening) use a thread sealer on the plug before re-installing.
Thanks,
S&S tech
Skogdog here:
Remember that your oil pump has two sides--one pumps oil through the engine oil galleries and lubes key friction points under pressure--no splash system like auto engines. The other side of the oil pump sends the oil through the filter and back to the reservoir.
This means that as long as there is oil in the reservoir available for the pump to use, the engine has oil pressure. So there is no time when the engine has to run without oil pressure after an oil change. A correctly operating pump (check ball) will not lose its prime if you drain the sump.
Believe what the tech says about not stripping the sump bolt...that would be a pain in the butt.
