Sounds like you just need to turn it a bit more thenThanks wrench!, sounds a lot better now, still not right but at least it’s threatening to rev a bit now, gonna check the coil next (as per mr Wright’s link) just to be sure
Yep, was thinking the same thing, hence my earlier post!My way of looking at the coil is... If the ign was adjusted, a rev is running past the previous setting, how all of a sudden is the coil the problem?
I'd loosen the ign bolts so I could swing the ign body in the slots, start the bike, WOT the throttle, move the body and see if the slots will advance the ign.
Note: Let's say the rotor spins clockwise. If you can image-12 o'clock is TDC (top dead center) is the piston. If the rotor moves to 11 o'clock, call this full advance. Therefore, I'd move the body in the slots in the counter clockwise position to see if it will rev with more advance. If the rotor moves ccw, then the body in the slots move cw. Make sense?
Have you read the install document yet? Specifically the belowSo, following wrench’s advice, I slackened of the two retaining screws enough to be able to make adjustments, fired it up, and the pick ups are arcing between the module and the back plate as the motor vibrates, so sadly that ain’t gonna work
https://www.google.com/url?sa=t&sou...FjABegQIAxAB&usg=AOvVaw3TvrhYbCqpLnodmqv0LIb7If the ignition has to be rotated an extreme amount or does not have enough adjustment to bring the timing in, the engine may be on its
exhaust stroke. Remove the ignition and observe the timing rotor. The timing pickup (near the switches) should be sitting in one of the
windows with the ignition installed . The shorter distance to the other window should be CLOCKWISE. If not, rotate the crankshaft 1
revolution and check again
When you said it was arcing when you had it loose, I figured it was the problem. I bet it's cracked or something like that. Drop another one in and go for a ride.Just a small update, the spark to the front cylinder is not consistent, in fact it’s not even a consistent misfire, it’s more a case of fire two , miss one , fire six miss two etc, etc. Coil and leads and plugs all check out so I think the finger is definitely starting to point at the ignition module , anyone know how to test them properly?, other than just trying to measure the outputs
