2) what happens when they both are breathing. Front sucks...rear blows when does that happen? All the time!
What I'm trying to say is I think you are fine tying them together but you gotta increase the circumference of the hose. Ideally you would want a check valve in the rear too so air can only go the way it's supposed to.
OK brother so here's the scoop, at least in regards to my motor and most evo motors- not sure about S&S SSW+ design it does look different.
The head breathers and case breather all "blow". there is no "suck". The rocker boxes have one way umbrella valves that vent pressure out only, no suck.
The bottom case breather vents pressure outward only. I have an inline check valve on the case breather hose which acts like the rocker box umbrella valve. I use an $8 Mercedes Turbo oil line breather check valve, it has a high speed reed valve and works fine in high heat applications. A lot of knucklehead guys use it. and it does not cost $100. lol. Part reference:
Pelican Parts - Product Information: 271-018-03-29-M604 - you can get an OEM Mercedes turbo breather valve at any Mercedes dealer for $10.
The Evo is a "split" oil system off the oil pump. There are two main ports off the pump, one shoots oil up the top of pump through the small filter screen to the top end (lifters, rockers etc)- the oil gauge runs off this feed, so you are only seeing your oil pressure for the top end of motor.
The other port from oil pump shoots oil down through the crankshaft, goes to rods, bearings, pistons. this does NOT show on the oil pressure gauge. So in my case, this port was plugged in the oil pump body and very weak oil to the bottom end of motor. Front piston ran dry, got hot, expanded, touched cylinder walls, game over. The rear piston did ok since it was getting some oil from crank wash.
My mech noticed there is some type of weird check ball in the TP oil pump body on the bottom end oil feed port and it was not working right. he tried to probe it a bit to try and free it up and it completely grenaded out of it's machined recess. I was comparing the TP oil pump to the new S&S HVHP oil pump and I have to say- DO NOT get a TP pump. they are in fact made very oddly.
Good learning session for me- It's a shit shame that there is no way to run a "bottom end" oil pressure gauge. So in rare situations like mine, you'll be showing fabulous oil pressure on the gauge to your top end only, but bottom end can be getting ZIP.
Lastly- the machine shop (R&D Machine in Costa Mesa) finished re-boring my cylinders and were able to save them just fine! The previous machine shop bored them a bit tight at 0024 clearance. this bore is at 0030 clearance, and all work was done on a Sunnen CNC machine specifically set up for V-Twin cylinders, TQ plates etc. All good. And get this!! The machinist said the front cylinder would not have been saveable if it was not cryo-treated- the added surface hardness of cryo-treating saved it from any serious damage. Definitely glad I had that done. New pistons are going in the cryo tank this weekend. Bike should be up for testing next weekend.
