Did you send it back to TH for them to check it?Axel,
I guess the ignition module may be bad? I will replace it before the next EHC.
Axel is doing a hell of a good job. He was not kidding about shipping cost. He keeps improving his product. You can tell he takes this seriously.Hi Todd,
Hm, this should not happen. Pls. send the EHC back to me for checking out. Do you have about 8 - 10 days time until I get the defect device or do you want me to send a new one asap? I would like to program the 3 flashes for the brake light in the new devices but need a few days if a small delay would be ok for you.
All the best!
Axel
That was fast shipping! Wow!Hi Todd,
I received the EHC and bring a new device from the 2. serie on the way today.
I have open the defect device and found out that there was an internal short circuit between 2 of the external cables. I believe that the first potting material had made the external cables soft while getting hard. I had used 2 cable straps inside of the potting compound what pressed the cables together and might result in the short circuit.
However, I already changed the internal wiring without cable straps at the 2. serie. So, this issue is a matter of past...
All the best!
Axel
Rottweiler, how many ehc's have gone bad in your bike?I have strong suspicions that the ehc wasn't the issue I don't think it's the first one that took a crap
Including Axel's Four now. Different problems first two, bike would not pass the power up test sometimes. last two no spark.Rottweiler, how many ehc's have gone bad in your bike?
Paul......I only tried the first one out to give axel a feel for it and to get some feedback.......I am running the same upgraded version that everybody else is running nowHey James, reading back thru this post seems like you were the first to try Axels ehc replacement and now he has an upgraded unit. Does this mean you need to get the upgraded unit or are you safe in running the first one. Just curious.
Did you figure out what the problem was with the ground going to the Ignition module and remove the extra ground you added?Hope not to see any more of the insides.Actually under the seat and out of mine would be great.
Update I bought a new ignition system which includes coil and wires. Changed to a single fire. Tested the VR for bad diodes. Also tested all wiring. Bike should be back on the road again soon.Can't wait we actually had a few days without RAIN here in PA.
Great job.. Glad to see ya back in action.. now clean that puppy up before Ker gets back..(Who'd have thunk black text blacks out, huh?!)
LMAO!! Love this forum!! ...Axel, Ker, & Curtis: Bike is up and running again, Axel's new EHC (58) fixed the issue with the bike full on (with the key sitting on my polishing chair!). (Adding my 2 cents since I was busy and didn't get to chime in) WORTH EVERY BIT OF $550.00, THANK YOU AXEL for the production, dissemination, follow-up & updates! OK, back to working on my freakin' Ark! Only 26 more days of rain here in S.C. PA...
Must be a PA thing, Ker does it all the time. Blahahahaahaha.Whew! I still need to go change my shorts, I think I wet myself.
Sent from my GT-P3113 using Tapatalk
