Axel
We had tested the EFI version today. Almost everything is fine and works as expected. There is only one issue: The low fuel led in the tachometer was permanent glow and the tank was almost full. In the original EHC schematic is just a bridge between A22 and B40 indicated. I have not found a low fuel sensor in the schematic, even when I use my eye glasses :-/
Any ideas?
By the way, I have checked the current from the constant power output of EHC to the EFI. It´s about 20 mA in standby and about 480 mA in use. So, there is just a small fuse necessary in he EHC. I´ll simulate a constant current circuit within the next days. This might be better in my opinion compare to an ordinary fuse and might be an option for the next version.
All the best!
Axel
Any ideas?
All the best!
Axel
